Dustin_V
May 24, 2019NETGEAR Employee Retired
Why Should I Upgrade to a WiFi 6 Router? - Blog
The latest generation of WiFi technology, WiFi 6 (802.11ax), is designed to increase network capacity and improve the performance of you home network. Ideal for the smart home of today, a WiFi...
ninja661
May 29, 2019Luminary
I have a question and hopefully there is an answer here - why upgrade to a WiFi 6 router when Netgear can’t get it right the first time? I’ve had Netgear products from an old Prosafe Firewall/router and the PS101 Parallel port Ethernet print server - these were 2 devices that worked as delivered but over the years i’ve had the WNR2000 v2, the R6300 and lastly the R8000. These all 3 routers have been nothing but major hardware fails and Netgear tells me after my warranty was still in effect on all of these devices they want me to subscribe to their extended warranty services - why would I feed money to a broken machine that never gets fixed? Nothing ever gets resolved with Netgear Support - always being routed overseas and techs always wanting remote sessions via my desktop. I have from past experiences to never let a Remote Desktop session unless it’s someone you trust implicitly. That said, why would anyone pour money into a broken machine? Netgear has a lot of convincing to do before I will ever consider one of their ‘routers’ again and the experiences I’ve had with Netgear routers I would have returned this R8000 within days after purchasing it and asking for a refund. One piece of advice to consumers - never trust reviews about hardware they are like driving a first model year of a new car out the showroom doors - expect a zillion bugs and hope they will get fixed. (Not the case here.)
myersw
May 29, 2019Master
Why would I want to buy one of these when Netgear cannot get the firmware right for the existing product line. Had ongoing issues with firmware with r8000 and r8000p and went else where. Netgear does not seem to have any QA in place for firmware updates. Have the same issues update to update. I will not recommend a Netgear router to anyone after my recent experience with the r8000 and r8000p. Have moved on to Ubiquiti Unifi. Now I never have issues with my network, unlike when using Netgear products.
David Henry in the other video obviously has not followed the forums or he would not indicate all you need to do is configure and forget your router. That is the way it should be, however that was not my experience with 2 of the "flagship" routers. The r8000 and r8000p had same issues update after update. JUNK!.
