Dustin_V
May 24, 2019NETGEAR Employee Retired
Why Should I Upgrade to a WiFi 6 Router? - Blog
The latest generation of WiFi technology, WiFi 6 (802.11ax), is designed to increase network capacity and improve the performance of you home network. Ideal for the smart home of today, a WiFi...
Dazzamatazz
Aug 15, 2019Tutor
My RAX80 Nightmare has been returned to Amazon. What a useless piece of junk it was. Constant disconnections, passwords that were accepted at time of entry then would throw 'incorrect password' errors randomly.
I couldn't even register my router for support because the error message said that my 90 day support had expired at a date 90 days in the future! I sent n email to "customer services" explaining the issue, and after 14 days have not recieved a reply.
I don't know what happened to Netgear as a company, but quality control is zero and support is useless. I will never trust or buy anything from Netgear again.
- myerswAug 15, 2019Master
Welcome to the Netgear haters club. They had been my go to company until firmware issues with a r8000 and r8000p. Moved away from consumer grade routers of any brand.
- DazzamatazzAug 16, 2019Tutor
I managed to pick up a Cisco cisco 3800 (AIR-AP3802I-E-K9) for a reasonable price off eBay. I hope once I get it going it will last for years without issue.
I've found out that it does come with challenges though. I've ordered a USB Console Cable with FTDI Chip to connect to the console. Then I have to convert it to run with Mobile Express software instead of CAPWAP in order to be able to use it without a dedicated hardware controller. To download the firmware from the Cisco site, I need a Cisco support contract, so I've had to find the .tar files elsewhere...
Fun and games, but I hope it will be worth it. Anything but consumer-grade junk!
- robledrewOct 19, 2019Apprentice
I went to the RAX200 from the R8000 and am learning the same thing.
As a tech industry professional, my advice would be to not invest in Netgear for your stock portfolio or your home networking needs. Not until they get their act together and start producing products that have been through QA and actually work as advertised!
- April1Dec 28, 2019GuideI had bought RAX75 earlier but didn’t get the speed. Netgear service agent told me that’s the max speed (200 mbps) I can get. I returned it and bought RAX80. It works great but keep losing 5G once in a day. Fan get on frequently. Appears to be a heat problem in the router. No one from the Netgear service is able to help me. Agents come and advice to perform factory reset and wait for a day. Nothing has worked so far. I work from home so reliable connectivity is a must for me to survive.
Netgear is not saying yes to replace the router possibly they are not sure if the next one will work ok
