Dustin_V
May 24, 2019NETGEAR Employee Retired
Why Should I Upgrade to a WiFi 6 Router? - Blog
The latest generation of WiFi technology, WiFi 6 (802.11ax), is designed to increase network capacity and improve the performance of you home network. Ideal for the smart home of today, a WiFi...
myersw
Aug 15, 2019Master
Welcome to the Netgear haters club. They had been my go to company until firmware issues with a r8000 and r8000p. Moved away from consumer grade routers of any brand.
Dazzamatazz
Aug 16, 2019Tutor
I managed to pick up a Cisco cisco 3800 (AIR-AP3802I-E-K9) for a reasonable price off eBay. I hope once I get it going it will last for years without issue.
I've found out that it does come with challenges though. I've ordered a USB Console Cable with FTDI Chip to connect to the console. Then I have to convert it to run with Mobile Express software instead of CAPWAP in order to be able to use it without a dedicated hardware controller. To download the firmware from the Cisco site, I need a Cisco support contract, so I've had to find the .tar files elsewhere...
Fun and games, but I hope it will be worth it. Anything but consumer-grade junk!
