Dustin_V
May 25, 2019NETGEAR Employee Retired
Why Should I Upgrade to a WiFi 6 Router? - Blog
The latest generation of WiFi technology, WiFi 6 (802.11ax), is designed to increase network capacity and improve the performance of you home network. Ideal for the smart home of today, a WiFi...
myersw
Aug 15, 2019Master
Welcome to the Netgear haters club. They had been my go to company until firmware issues with a r8000 and r8000p. Moved away from consumer grade routers of any brand.
robledrew
Oct 20, 2019Apprentice
I went to the RAX200 from the R8000 and am learning the same thing.
As a tech industry professional, my advice would be to not invest in Netgear for your stock portfolio or your home networking needs. Not until they get their act together and start producing products that have been through QA and actually work as advertised!
- April1Dec 29, 2019GuideI had bought RAX75 earlier but didn’t get the speed. Netgear service agent told me that’s the max speed (200 mbps) I can get. I returned it and bought RAX80. It works great but keep losing 5G once in a day. Fan get on frequently. Appears to be a heat problem in the router. No one from the Netgear service is able to help me. Agents come and advice to perform factory reset and wait for a day. Nothing has worked so far. I work from home so reliable connectivity is a must for me to survive.
Netgear is not saying yes to replace the router possibly they are not sure if the next one will work ok- schumakuJan 28, 2020Guru - Experienced User
RAX75 (AX5700) and RAX80 (AX6000) are essentially sharing the very same hardware, even the firmware is (internally) identical. The only difference is the max. link speed on 2.4 GHz which is firmware-limited to 300 Mb/s less:
RAX75 (don't be confused - the marketeers still claim it 920Gbps....)
802.11ax Dual Band WiFi (AX5700)
2.4GHz AX: 4x4 (Tx/Rx) 1024 QAM 40MHz, up to 920Mbps
5GHz AX: 4x4 (Tx/Rx) 1024 QAM 160MHz, up to 4.8Gbps
RAX80:- 802.11ax Dual Band WiFi (AX6000)
2.4GHz AX: 4x4 (Tx/Rx) 1024 QAM 40MHz, up to 1.2Gbps
Wonder what hero claimed the RAX75 can only do 200Mb/s - under whatever unclear conditions - probably becuase of some limitations resp. the technology in place on a wireless client.
Fan can come up if the device - or some components - are running hot, cloud be a hardware thing. I'd push them to send a replacement unit (up front).
- mayeen12Apr 15, 2020Star
YOU SHOULD NOT UPGRADE TO WIFI 6 router, NETGEAR can't even support the WAN speed.
My house have MANY wifi 6 devices.. I can't even take full advantage of it, becuse of netgear WAN limitation of 500 MBPS.
