BoutrosLowe
Apr 20, 2021Initiate
Wi -Fi 6 Access Points to use with RAX40
The Minister for Finance won't approve the purchase of AX11000 - to be honest it was "overkill" so now Plan B is Nighthawk AX4. As this has to go into the garage (worst possible place to put the eth...
Apr 21, 2021Guru - Experienced User
If you're wanting multiple AP's, I'd highly recommend going the route of either netgear orbi or nighthawk MK series. they both support wired backhaul and then you'd have seamless roaming between them.
