BoutrosLowe
Apr 20, 2021Initiate
Wi -Fi 6 Access Points to use with RAX40
The Minister for Finance won't approve the purchase of AX11000 - to be honest it was "overkill" so now Plan B is Nighthawk AX4. As this has to go into the garage (worst possible place to put the eth...
Apr 21, 2021Guru - Experienced User
If you're wanting multiple AP's, I'd highly recommend going the route of either netgear orbi or nighthawk MK series. they both support wired backhaul and then you'd have seamless roaming between them.
BoutrosLowe
Apr 21, 2021Initiate
I had initially ruled out the Orbi and MK series as they don't have a USB port for the NAS / Timemachine back up + the lack of ports means buying at least one switch + they are expensive compared to a Router (with better performance) + Extender/WAP(s). Will go back and revist though - thanks again for the prompt reply and advice
- plemansApr 21, 2021Guru - Experienced User
For those that rely on backup/network storage, I usually recommend a basic (or more) nas setup. Even an old computer can be used as a nas with free software.
You'll have better performance and reliablility.
