BoutrosLowe
Apr 20, 2021Initiate
Wi -Fi 6 Access Points to use with RAX40
The Minister for Finance won't approve the purchase of AX11000 - to be honest it was "overkill" so now Plan B is Nighthawk AX4. As this has to go into the garage (worst possible place to put the eth...
BoutrosLowe
Apr 21, 2021Initiate
I had initially ruled out the Orbi and MK series as they don't have a USB port for the NAS / Timemachine back up + the lack of ports means buying at least one switch + they are expensive compared to a Router (with better performance) + Extender/WAP(s). Will go back and revist though - thanks again for the prompt reply and advice
Apr 21, 2021Guru - Experienced User
For those that rely on backup/network storage, I usually recommend a basic (or more) nas setup. Even an old computer can be used as a nas with free software.
You'll have better performance and reliablility.
