Jimmy_W
Jul 08, 2021Guide
Wi-Fi 6 band drops speed, needs reboot
Hi so for some reason my RAX200 have started droping speeds after a couple of days on the Wi-Fi 6 band, running channel 128 5ghz-2 band.
I only have one device connected.
If i reboot the router then i get full speed for 2-3 days then it falls back to maximum 200mbps.
Full speed i get 1200mbps.
On my other bands i do not recive any speed drop they stay stable all the time.
Firmware version: V1.0.4.120_1.0.61
Have you tried changing the channel you're on?
the 128 is a dfs channel and maybe you're getting radar in the area.
- Jimmy_WGuide
plemans Thank you for answering, the wierd part is that it's fine instantly after i restart it then i get full speed again and staays like that for days, if it was radar would i still have the same speed after my restart?
Exampel.
Testing speed now: 200mbpsRestart router 10min wait: 1200+ mbps
What device are you testing on?
Are you talking link speeds are actual tested throughput?
