GTI
Jul 09, 2022Aspirant
Wi-Fi 6
I have a Nighthawk AC1900 with voice router. What is the equivalent model that isWi-Fi 6 compatible?
Jul 09, 2022Guru - Experienced User
AC1900 is a speed, not a model.
what actual model do you have?
What are you trying to do? If you're upgrading to an AX device, you have lots of potential from staying at the same basics to increasing the speeds all the way to triband or mesh. Are you wanting the same basic thing or wanting an upgrade (whole point of going AX)
GTI
Jul 17, 2022Aspirant
C7100B is the model number. Want eliminate dead spots. Faster WiFi would be better with wifi6? I’d Xfinity’s hardware better than what is available to buy?
- GTIJul 17, 2022AspirantMy Gateway is a Netgear C7100V, correction.
- plemansJul 17, 2022Guru - Experienced User
the C7100v is a pretty solid device. How big is your home?
It might be better to switch to a mesh system versus just upgrading the router.I say that because t he C7100v has pretty good coverage and upgrading to AX isn't going to get you much additional coverage.
reason why is the broadcast strength wasn't increased with the move from AC to AX routers. they get a little extra range just because of increased efficiencies but its not a lot. So if you have dead spots, it might be better to switch a mesh system that you can have 1 or more satellites to provide coverage.
- GTIJul 17, 2022AspirantThe house is 2400sqft
