mcf58's avatar
mcf58
Wi-Fi Extenders - Best choice to connect with Nighthawk AX6000 v2
I have a Nighthawk router connected to AT&T Pace model 5268AC modem. I do not have good coverage and was looking to add extenders. Currently the router is upstairs in a 3200sq ft, 2 story house and c...
  • plemans's avatar
    Aug 25, 2021
    most should work but its all depends on what exactly you'd like. I'd either recommend using the EAX line or the triband AX lines.
    there's AX extenders like the EAX15, EAX20, EAX80
    And the tribands are the EX7500, EX7700, EX8000
    theres benefits to each and differences in prices.
