mcf58
Aug 25, 2021Aspirant
Wi-Fi Extenders - Best choice to connect with Nighthawk AX6000 v2
I have a Nighthawk router connected to AT&T Pace model 5268AC modem. I do not have good coverage and was looking to add extenders. Currently the router is upstairs in a 3200sq ft, 2 story house and c...
- Aug 25, 2021
most should work but its all depends on what exactly you'd like. I'd either recommend using the EAX line or the triband AX lines.
there's AX extenders like the EAX15, EAX20, EAX80
And the tribands are the EX7500, EX7700, EX8000
theres benefits to each and differences in prices.
Aug 25, 2021Guru - Experienced User
mcf58
Could you tell me about the differences and benefits of each type? I'm not worried about cost, I just don't want to have to replace them in a year or 2.
- plemansAug 25, 2021Guru - Experienced User
Benefits to a triband extender is it has a dedicated backhaul between router----extender.
It has lower latency and higher speed (potentially). Versus a single/dual band extender takes a 50% speed reduction because it has to use the same wireless chip to go router----extender and then extender----devices. And it can't do both at once.
But the EAX series is a AX extender so it has a theoretically higher potential connection. So even at a 50% reduction, it potentially is still faster. It'll have a bit higher latency though.
so it comes down to what you want to try and budget.
As well as what you're using it for.
If you're gaming, I'd go with a tri-band.
If you're streaming tv/standard browsing, a dual band would suffice
