Kyloh3n
Apr 02, 2023Aspirant
WI-FI not connecting to any device in household
I have been trying to connect to the Wi-Fi all day and I called the ISP and everything is fine with the internet, I see the router is getting the internet, I checked on the app and web it is connected...
- Apr 02, 2023
Would be helpful to know what NG router model your referring too.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Apr 02, 2023Guru - Experienced User
- Kyloh3nApr 02, 2023AspirantHello apologies it’s for the nighthawk ax5400 6 stream wifi routr. I’m trying those steps now, I was able to contact the ISP and everything was good on their side, I even plugged my laptop straight to the modem and it was working. I haven’t tried the factory reset settings but I may have to try that
- FURRYe38Apr 02, 2023Guru - Experienced User
That a RAX###?
- michaelkenwardApr 03, 2023Guru - Experienced User
Kyloh3n wrote:
Hello apologies it’s for the nighthawk ax5400 6 stream wifi routr.That could be one of several Netgear devices. RAX50? XR1000?
Look at the label on the thing for the Model Number.
Model number label
