alud7_ru
Nov 16, 2019Aspirant
Wi-Fi reconnects randomly
A RAX120 router worked flawlessly for a month. A week ago wi-fi started to disconnect and reconnect each 5 or 15 or 30 minutes. I downgraded from 1.0.1.100 to 1.0.0.84. The router worked a week after...
Christian_R
Nov 19, 2019NETGEAR Employee Retired
Hello alud7_ru,
Welcome to the community! Have you gotten a chance to open a support ticket with our support team?
https://www.netgear.com/support/default.aspx
Christian
alud7_ru
Nov 21, 2019Aspirant
So, what they told me didn’t help at all. It just reconnects.
Any suggestions?
Any suggestions?
- GabboCHNov 25, 2019Apprentice
Welcome to the wonderful world of Netgear Wifi6.....
Connect/Disconnect/Connect/Disconnect..... Reboot.......
Check out the other community threads for the RAX120 or RAX80.
There are many users reporting the same issues.
You can disable SmartConnect, disable AX, BeamForming, QoS & the reboot might correct the problem for a short time but the same issue will come back.
- alud7_ruNov 25, 2019AspirantI see. So the issue is in firmware I think.
They told me to set CTS/Rts to 2303. Did so and waiting for the next reboot.
