alud7_ru
Nov 16, 2019Aspirant
Wi-Fi reconnects randomly
A RAX120 router worked flawlessly for a month. A week ago wi-fi started to disconnect and reconnect each 5 or 15 or 30 minutes. I downgraded from 1.0.1.100 to 1.0.0.84. The router worked a week after...
alud7_ru
Nov 21, 2019Aspirant
So, what they told me didn’t help at all. It just reconnects.
Any suggestions?
Any suggestions?
GabboCH
Nov 25, 2019Apprentice
Welcome to the wonderful world of Netgear Wifi6.....
Connect/Disconnect/Connect/Disconnect..... Reboot.......
- GabboCHNov 25, 2019Apprentice
Check out the other community threads for the RAX120 or RAX80.
There are many users reporting the same issues.
You can disable SmartConnect, disable AX, BeamForming, QoS & the reboot might correct the problem for a short time but the same issue will come back.
- alud7_ruNov 25, 2019AspirantI see. So the issue is in firmware I think.
They told me to set CTS/Rts to 2303. Did so and waiting for the next reboot.- GabboCHNov 25, 2019ApprenticeI'm 100% sure these issues are firmware related but I current have 0% confidence they are being resolved.
Will be interesting to hear back on how the CTS setting affects your issues.
