April1
Dec 24, 2019Guide
WiFi 5G dropping on RAX80
I got a new AX8 router, updated FW to the latest, rest to factory status, QOS disabled, AX enabled, set 5G channel to 161 and also tried 36, noticed two issues: 1. Fan is noisy 2. 5G radio drops aft...
hsman
May 15, 2020Tutor
Same here ...
After some days, I can't connect to 5Ghz. Reboot solve the problem.
Is new firmware coming? I'll wait a bit but after that, i will resend it to Amazon !
- GabboCHMay 15, 2020ApprenticeIf you look how long the threads have been open relating RAX issues with Wi-Fi, Ethernet & other issues this is your answer...
According to netgear, there is no issue.
There have been no firmware changes in the 6 months+ that I've owned the device that change anything except for adding localisation tweaks.
Give it back for a refund and choose another brand while you still can...!- scott2003lhsMay 16, 2020StarI have the RAX 40 and it does the same stuff. What a disappointment. I am way out of return window. I’m considering another brand.
