April1
Dec 24, 2019Guide
WiFi 5G dropping on RAX80
I got a new AX8 router, updated FW to the latest, rest to factory status, QOS disabled, AX enabled, set 5G channel to 161 and also tried 36, noticed two issues: 1. Fan is noisy 2. 5G radio drops aft...
hsman
May 17, 2020Tutor
I just discover this problem. 950Mbps without router (pc direct connected) and 500 with router. I will try to leave on QoS after multi reboot (qos off, reboot then on and reboot) as you said.
But ... I am just waiting my new ax88u before send back my rax80 so...
