April1
Dec 24, 2019Guide
WiFi 5G dropping on RAX80
I got a new AX8 router, updated FW to the latest, rest to factory status, QOS disabled, AX enabled, set 5G channel to 161 and also tried 36, noticed two issues: 1. Fan is noisy 2. 5G radio drops aft...
brucescar
Dec 01, 2020Aspirant
Same issue on RAX48, doesn't look like there's any solution. I should just return this.
Ferjy_Fangle
Mar 22, 2021Aspirant
Having the same problem with my RAX45.
- GabboCHMar 22, 2021ApprenticeJust take it back and buy something else.
Ive been waiting 18 months for a fix but not even 1 attempt to fix it from Netgear. - Ferjy_FangleMar 23, 2021Aspirant
Has anyone gotten these instructions from Netgear Customer Support regarding this issue?? And are they worth trying?
"I will be asking you some questions to further isolate the case.
-Who is your internet service provider?
-Do you have an existing gateway or router behind this router?
-What's the firmware version of the router?
-Have you tried to change the wireless channels of the router?
Kindly launch a browser, routerlogin.net or 192.168.1.1
An admin log in will pop up, username is admin all in lower case and for the password if you already set up an admin password before use that one if not yet use password as password all in lower case
To change the WiFi channel, kindly select Wireless under basic tab. Then, select a number from the Channel menu.Kindly change the wireless network channel to:
2.4GHz - 11
5GHz - 161or this one
2.4GHz - 9
5GHz - 44
Then click save/apply.
-Have you tried to change MTU size?
To change the MTU size. On the router's dashboard, kindly select ADVANCED > Setup > WAN Setup.
In the MTU Size field, enter a 1492 value. Then, click the Apply button.-Have you tried to set a static DNS on the router?
On the BASIC Home screen, select Internet. Under the Domain Name Server (DNS) Address section, select the radio button for Use these DNS Servers. Enter the following:
Primary DNS - 8.8.8.8
Secondary DNS - 8.8.4.4
Then click Save/Apply.Kindly monitor the router for 12-24 hours."
- Ferjy_FangleMar 28, 2021Aspirant
Has anyone with these problems tried a Factory Reset and then a manual entry of the parameters?
This has cured other strange Netgear router problems I have had in the past.
- alokbhargavaMar 28, 2021TutorYes factory reset after software update helps.
