ghildrew
Sep 06, 2019Follower
WiFi 6 - Orbi or Nighthawk
I've had an RAX200 on preorder for months, but just saw the newly announced Orbi RBK852. Forgive my ignorance, but can someone explain why one might be better for myself? I work in the enterta...
Sep 07, 2019Guru - Experienced User
the benefit to Orbi is its mesh backhaul and orbi controlling which satellite devices connect to while roaming. both orbi and the RAX have band steering.
Stucco walls do a great job of blocking signals. I'd be willing to place money on those walls causing all your current wireless issues. Orbi would do better than just a single RAX200. However, with stucco walls and multiple levesl, your best is going to be trying to get ethernet lines ran and using ethernet as the backhaul. It doesn't matter how great a device's wireless backhaul is if the signals can't penetrate. This is going to be true of any wireless setup you do.
