toylexus
Jul 05, 2024Tutor
Wifi 6 ax1800
Hello all. As an elderly person I'm not very clued up to all this technology. Basically I want to buy a new router but I need something that will take the same two leads that go into the back of my ee...
michaelkenward
Jul 05, 2024Guru - Experienced User
toylexus wrote:
Basically I want to buy a new router but I need something that will take the same two leads that go into the back of my eero router.
What do you want this new router to do that you can't achieve with the eero router?
Is the idea to replace the eero? What model number is it.
What hardware do you have that connects you to the Internet?
