Dustin_V
Nov 19, 2019NETGEAR Employee Retired
WiFi 6 ISN'T a Big Deal...Or Is It?!
WiFi 6 is here, and devices supporting the new standard are starting to hit store shelves, both off- and online. WiFi 6 promises to bring faster speeds and greater capacity... but there are some ...
SeaRefractor
Mar 20, 2021Apprentice
For what was promised out of the box, my RBK753 Orbi system has delivered. As to why I purchased the AX4200 product line of WiFi 6 mesh, I've seen the details on WiFi 6E and would rather save my money for that as an upgrade at some point. For more details as to what WiFi 6E is, see the PDF you can download from the WiFi Alliance here https://www.wi-fi.org/download.php?file=/sites/default/files/private/Wi-Fi_6E_Highlights_202101.pdf
While WiFi 6E is not a replacement to WiFi 6, it's certainly an enhancement. Also to have that much of a change (whole new frequency range) added before there's a significant amount of WiFi 6 devices does make me feel that it was held back to try and artificially encourage a short upgrade cycle.
In any event, I'm glad I didn't drop too much on an AX6000 (over $1000 for RBK853) solution only to have an AX11000 product line already being released by the competition.
At least it'll be much more fully baked before the next Orbi environment is released for the WiFi 6E, so I'll be more confident at that point once released.
Tofu-Golem
May 06, 2021Apprentice
SeaRefractor wrote:For what was promised out of the box, my RBK753 Orbi system has delivered. As to why I purchased the AX4200 product line of WiFi 6 mesh, I've seen the details on WiFi 6E and would rather save my money for that as an upgrade at some point. For more details as to what WiFi 6E is, see the PDF you can download from the WiFi Alliance here https://www.wi-fi.org/download.php?file=/sites/default/files/private/Wi-Fi_6E_Highlights_202101.pdf
Agreed.
There are few client devices that can even use the new 6 GHz band, and even if you have such a device, the 6 GHz band is going to be even worse at penetrating physical obstructions like floors and walls than the 5 GHz band.
Right now, the best use of that new 6 GHz band is as a dedicated backhaul for mesh systems designed to use it.
