Bbtbbt
Mar 10, 2023Initiate
Wifi 6 Netgear RAX10
Can this router be loaded with Expressvpn
- Mar 10, 2023
expressvpn literally has a site with what routers they support.
https://www.expressvpn.com/support/knowledge-hub/supported-devices/#routers
Its third party firmware and you won't find support for it on the official forums.
michaelkenward
Mar 10, 2023Guru - Experienced User
There are dozens of VPNs out there. Netgear can't test them all.
The best people to ask which devices support a VPN system are the suppliers.
So, talk to ExpressVPN
