Bbtbbt
Mar 10, 2023Initiate
Wifi 6 Netgear RAX10
Can this router be loaded with Expressvpn
- Mar 10, 2023
expressvpn literally has a site with what routers they support.
https://www.expressvpn.com/support/knowledge-hub/supported-devices/#routers
Its third party firmware and you won't find support for it on the official forums.
Mar 10, 2023Guru - Experienced User
- michaelkenwardMar 10, 2023Guru - Experienced User
Duh, I should have known that.
Thanks for making up for my ignorance!
Might be a good idea for Netgear to create a KnowledgeBase article on VPNs with links to some of the better known services.
