russellstark
Oct 16, 2020Aspirant
Wifi 6 router general question about SSID count
Hello, I have many smart home devices that run on only the 2.4ghz band. I also know it is prudent to keep smart home devices off the same network as your home office. I am looking for a device that...
russellstark
Oct 18, 2020Aspirant
-The question is if netgear makes a device with these specifications, like the amplifi alien. My network is secured on my wifi, but the problem lies in that many smart home devices have alternate ways of hacking besides wifi (bluetooth, ability to become a temporary access point) If access is gained to the smart device there is a small chance the device could be used to access other network resources.
-The reason for wanting to split the smart home devices is based on the reccomendation of the FBI in this article
https://www.fbi.gov/contact-us/field-offices/portland/news/press-releases/tech-tuesday-internet-of-things-iot
I am just asking as brands make devices with this ability and would like to know if netgear makes a device with this ability.
rinthos
Oct 18, 2020Luminary
So separate SSID won't necessarily do the trick, you would need to segment each SSID as a separate VLAN.
You're looking at enterprise-class routing if you want an all-in-one device to handle that.
One way to accomplish this is get a separate router for each device with it's own subnet, and configure your firewalls to not pass traffic between them.
That would be rediculously expensive and wasteful though.
There IS a way to accomplish this really cheap. Turn on Guest WiFi, and connect all the devices to the Guest WiFi SSID.
Then DISABLE the option to Allow guests to see each other and access my local network.
That would completely Isolate each device. You won't be able to access the devices on your local LAN, however...
AND..if you enable the ability to communicate with devices on the local LAN, then that would invalidate the bullet from the FBI article you posted.....
In principal that recommendation is good...but it may not be practical for a lot of IoT devices..
Hope this gives you some options and helps...
- rinthosOct 18, 2020Luminary
Sorry, also meant to post the link to NetGear's Guest WiFi config page showing the options:
https://kb.netgear.com/000053086/How-do-I-set-up-the-guest-WiFi-on-my-Nighthawk-Pro-Gaming-Router
While this applies to the gaming routers, many of the regular RAX routers also support this.
Just check the user manual for the Netgear router you're interested in.
For example the RAX35 is a fairly cheap AX WiFi router but supports it:
https://www.downloads.netgear.com/files/GDC/RAX35/RAX35_UM_EN.pdf
