Pulpure
Aug 29, 2020Tutor
Wifi 6 Router
Hello I was very happy with the Nighthawk Mesh Wifi 6 being able to successfully set up. One thing I notice was that you can not manually select the band (2.4GHz or 5GHz) I can only set...
Aug 29, 2020Guru - Experienced User
that's it exactly. Bandsteering can move device between bands based on signal strength and bandwidth needs.
