Pulpure
Aug 29, 2020Tutor
Wifi 6 Router
Hello I was very happy with the Nighthawk Mesh Wifi 6 being able to successfully set up. One thing I notice was that you can not manually select the band (2.4GHz or 5GHz) I can only set...
Aug 29, 2020Guru - Experienced User
that's it exactly. Bandsteering can move device between bands based on signal strength and bandwidth needs.
Pulpure
Aug 29, 2020Tutor
Thanks for confirming.
That is awesome!
I have not yet set up the satellite and I am not sure where to set it up...
How far is ideal from the router?
Thank you
- plemansAug 29, 2020Guru - Experienced User
You need at least 30 ft between the router and satellites for the roaming to function properly.
In terms of placement. I'd try several spots. I moved my setup around repeatedly to optimize placement. Reason why is things in walls (hvac, plumbing, etc) can create dead spots interference and I'm a bit OCD about optimizing :)
- PulpureAug 29, 2020Tutor
If I find that I am not getting a good wifi signal at a certain area of the house does that mean setting up the satellite there would not be the ideal place?
For the most part, sure.
The orbi might have better range connection but it still needs a decent wireless backhaul to function.
You can log into the routers login page and check the backhaul status.
