Pulpure
Aug 29, 2020Tutor
Wifi 6 Router
Hello I was very happy with the Nighthawk Mesh Wifi 6 being able to successfully set up. One thing I notice was that you can not manually select the band (2.4GHz or 5GHz) I can only set...
Pulpure
Aug 29, 2020Tutor
Thanks for confirming.
That is awesome!
I have not yet set up the satellite and I am not sure where to set it up...
How far is ideal from the router?
Thank you
Aug 29, 2020Guru - Experienced User
You need at least 30 ft between the router and satellites for the roaming to function properly.
In terms of placement. I'd try several spots. I moved my setup around repeatedly to optimize placement. Reason why is things in walls (hvac, plumbing, etc) can create dead spots interference and I'm a bit OCD about optimizing :)
- PulpureAug 29, 2020Tutor
If I find that I am not getting a good wifi signal at a certain area of the house does that mean setting up the satellite there would not be the ideal place?
- plemansAug 29, 2020Guru - Experienced User
For the most part, sure.
The orbi might have better range connection but it still needs a decent wireless backhaul to function.
You can log into the routers login page and check the backhaul status.
Orbi and Nighthawk
What are the difference?
