woodies
Nov 29, 2020Tutor
wifi 6 with vpn preinstalled
hi i was wondering if a vpn like vpnexpress comes pre installed in any wifi 6 routers... and if not.. why are wifi 6 routers unable to have a vpn? thanks
Nov 29, 2020Guru - Experienced User
Its not that they're "unable to have a vpn". Its just that many vpn's have custom firmware they install to the router.
Usually what happens is the open source community gets a stable firmware version running for a router and vpn companies use and adapter it for what they need for their vpn.
Wifi 6 routers are pretty new and the open source community (dd-wrt) doesn't have much for builds right now. Plus there isn't as many AX routers out there so there isn't a financial push from VPN makers to devote resources ($) to builds yet.
So you don't see much for VPN companies offering customized firmware for wifi 6 routers yet. I imagine it'll come with time/exposure.
- woodiesNov 29, 2020Tutor
Thanks for your reply appreciated.
So if one wants to stream or game or have security for example its not much use at the moment to buy a wifi6 router then i take it.
I wonder if these routers sell well then.
So my best bet is just stick to my nighthawk 7000r and use express vpn i suppose...is that going to slow my speeds down much could you tell me? and I'm very vpn dumb at the moment in regards to setting these up or how you even use a vpn service... does netgear help with that? I'm trying to work out the best solution to add a vpn service and i'd rather expressvpn than any others ive compared to
- plemansNov 30, 2020Guru - Experienced User
woodies wrote:Thanks for your reply appreciated.
So my best bet is just stick to my nighthawk 7000r and use express vpn i suppose...is that going to slow my speeds down much could you tell me?---The VPN will slow it more than anything else because traffic has to be routed through the vpn. and I'm very vpn dumb at the moment in regards to setting these up or how you even use a vpn service... does netgear help with that?-----no, express vpn is its own custom firmware option. If you're using it, you need to go through expressvpn for support with speeds/performance. I'm trying to work out the best solution to add a vpn service and i'd rather expressvpn than any others ive compared to
