Bal-
Mar 30, 2021Guide
WiFi 6E Problems - RAXE500
I've recently configured my Netgear RAXE500 router and experiencing issues with very slow speeds and low signal with Wi-Fi 6E and I'm unable to authenticate with WPA3-Personal using the Intel AX210 m...
Altsai
Jun 29, 2021NETGEAR Expert
How to Enable Wi-Fi 6E/ 6GHz Band Using Intel® Wi-Fi 6E AX210 (Gig+)
GatorBait
Jul 14, 2021Tutor
Nothing seems to work for Windows or Linux. Definately an Intel problem. Keep wasting our time blaming Windows when it's certainly obviouse that Intel that can't seem to figure this out. Is there another wifi 6e card from someone that KNOWS what they are doing?!
- martyr444Jul 14, 2021Apprentice
6G Wifi works on my Samsung Ultra but not on my Windows 10. It's either the AX210 Card or Windows 10 for me not working. Intel support will say it's because not all of these AX210 cards are authentic Intel.
- Razor512Jul 15, 2021Prodigy
6GHz works fine if no password is set,
While there are a number of fakes floating around, they wre typically sellers on ebay slapping AX210 stickers on AX200s and then selling them for $30+ instead of the usual $15-$17 range. Their hope is that some users will not know before the the buyer protection window ends.
As for a genuine AX210, it does work fine, I am using one right now with my RAXE500 though since I am not using an insider build of windows, I don't keep it open for long.
As for linux distros, support is hit or miss depending on the distro, where some will have WPA3 working on the 6GHz band and others will not, and there isn't much help on their forms for it since there aren't many people with AX210s yet.
- martyr444Jul 15, 2021Apprentice
Yes, I can get mine to work with open too, but I would only use it with security enabled so that's not an option for me. If it worked with security other than WPA3 it would be an option. WPA3 is what the issue is for sure.
