Bal-
Mar 30, 2021Guide
WiFi 6E Problems - RAXE500
I've recently configured my Netgear RAXE500 router and experiencing issues with very slow speeds and low signal with Wi-Fi 6E and I'm unable to authenticate with WPA3-Personal using the Intel AX210 m...
Razor512
Jul 14, 2021Prodigy
6GHz works fine if no password is set,
While there are a number of fakes floating around, they wre typically sellers on ebay slapping AX210 stickers on AX200s and then selling them for $30+ instead of the usual $15-$17 range. Their hope is that some users will not know before the the buyer protection window ends.
As for a genuine AX210, it does work fine, I am using one right now with my RAXE500 though since I am not using an insider build of windows, I don't keep it open for long.
As for linux distros, support is hit or miss depending on the distro, where some will have WPA3 working on the 6GHz band and others will not, and there isn't much help on their forms for it since there aren't many people with AX210s yet.
martyr444
Jul 14, 2021Apprentice
Yes, I can get mine to work with open too, but I would only use it with security enabled so that's not an option for me. If it worked with security other than WPA3 it would be an option. WPA3 is what the issue is for sure.
- Razor512Jul 14, 2021Prodigy
Sadly that is an issue with microsoft. They have WPA3 working on the 6GHz band on their dev builds, but they won't just release a smaller update to push the proper 6GHz WPA3 support out to their mainstream builds, and instead are making people wait until they they finish working on a bunch of other stuff that most people won't want.
- martyr444Jul 14, 2021Apprentice
Someone tested Windows 11 but it was still a no go. It must just be certain dev builds that have WPA3 working.
- pdegan2814Jul 18, 2021Tutor
MS just announced the 21H2 feature update for Windows 10, and one of the features they say will be in it is "Adding WPA3 H2E standards support for enhanced Wi-Fi security", and H2E is what's needed for WPA3 to work on the 6GHz band, so I guess we have our answer. And I'm guessing that the official release version of Windows 11 will have it too(because supporting it in Win10 but not Win11 would just be idiotic).
- martyr444Jul 18, 2021Apprentice
Probably due October or later this year.
- AltsaiDec 08, 2021NETGEAR Expert
Regarding Windows 10, MSFT doesn’t mention support for Wi-Fi 6E, only WPA3-Personal H2E:
