Bal-
Mar 30, 2021Guide
WiFi 6E Problems - RAXE500
I've recently configured my Netgear RAXE500 router and experiencing issues with very slow speeds and low signal with Wi-Fi 6E and I'm unable to authenticate with WPA3-Personal using the Intel AX210 m...
Feb 01, 2022Guru - Experienced User
I would review this:
I haven't had a chance to check my PC again with newer FW. Been busy playing with other items. :smileywink:
petru44o wrote:
Hello Netgear Community!
I wonder if things got any better these days?
Can someone confirm I can use Windows 10 PC with this Fenvi FV-AXE3000 Wi-Fi 6E AX210, Bluetooth 5,2, PCIExpress adapter
And this RAXE500 router to get full Wifi6E experience?
I know that AX210 has only 2x2 TX/RX Streams; Bands 2.4Ghz, 5Ghz, 6Ghz, (160Mhz) would I be able to use its full potential with RAXE500?
Is there a way to unlock power for 6Hz LPI power restrictions if router is used outside the US?
martyr444
Feb 01, 2022Apprentice
I'm using the latest Netgear Beta Firmware for the RAXE500. I have never been able to get the SSID to show up for my Intel AX210 unless I use a hacked driver dated back to April 2021 by Dong. I also use the latest Intel AX210 Driver and still no show unless I use that hacked driver. I'm on the latest version of Windows 10 insider version 21H2 (OS Build 19044.1503).
