Bal-
Mar 30, 2021Guide
WiFi 6E Problems - RAXE500
I've recently configured my Netgear RAXE500 router and experiencing issues with very slow speeds and low signal with Wi-Fi 6E and I'm unable to authenticate with WPA3-Personal using the Intel AX210 m...
petru44o
Feb 02, 2022Aspirant
> Forgot to mention that Some WiFi adapters will determine region and apply local regulations based on beacons sent by nearby APs
Is there any understanding of how to choose AX210 card that does not use LAR (system that does what you described, as I understand)?
Is this detection of the region mechanism present on every intel ax210? Any tips how to avoid that?
Is this related to usage of the AX210 in the laptop or PCI to m2 usage in desktop is also vunerable to region determination? Thing is I wanted to test it in country, where 6Ghz is not yet certified.
petru44o
Does LAR takes in considiration only region of my AP, or neighbours SSIDs have this info broadcasted?
