Dap-68's avatar
Dap-68
Wifi booster
I'm looking to boost my wifi signal at my house. To my shop. Which is 100' away. Is this possible?
  • I'm not sure what product I need. That's why I'm asking this question
    Basic answer to your question is yes, but.
    Does your shop have power in it that originates from a subpanel to the house?
    If yes, you might consider a power line extender.  As an example only from Amazon, https://a.co/d/1HRePwu.
    • microchip8's avatar
      microchip8
      Master
      WiFi signals can go only so far. WiFi has a finite reach due to physics, which you can't beat at its own game. There is no magic you can use to extend the signal. 100' is a "long" distance and even if you get some signal, it'll be pretty weak.
    • plemans's avatar
      Would a wifi range extender make the distance? Maybe
      but you could do it right and either run an ethernet wire or use something like a point to point system.
      Netgear has Airbidge but its been going in/out of stock (more out of stock) lately.
      so it might be worth looking on amazon for other point to point systems that you could use.
