GoldenJ
Feb 26, 2022Guide
WIFI cannot detect the router RAX45
I installed Nighthawk AX4300 (RAX45 bought from COSTCO). Oddly, some of my WIFI computers cannot see the router SSID. These computers can detect a bunch of other routers which don't belong to me. Th...
Feb 27, 2022Guru - Experienced User
Some old devices had issues when AX was first released. it was fixed mainly with driver updates to them. Sadly, most of the drivers aren't on the windows or sony/lenovo/dell/etc sites. You had to go directly to the wifi device manufacturer website. So if you're computer has an intel wireless card in them (intel's were known for this), you had to go to the intel site and get them directly.
Have you tried this?
If you have and it doesn't work, try disabling AX on the router.
GoldenJ
Mar 06, 2022Guide
I updated the driver from vendor's website. Unfortunately, it didn't resolve the problem. Obviously, I don't want to disable AX to lose the benefit of wifi 6. So bad that the advance of technology is not comptible with old one, which was actually not too old. Thanks for the help.
- plemansMar 06, 2022Guru - Experienced User
what actual wireless cards are in the laptops?
What driver did you install?
As a standby, you could always connect the old router in access point mode to the RAX
- GoldenJMar 06, 2022Guide
The card is Intel dual band wireless AC 7260 card. I downloaded the driver file "bt_21.10.1_64_win10" from Intel's website and installed it. Now what I have done is to use an WiFi extender connected to the router and connected my computer to the extender. You mentioned to connect the old route in access point mode to the RAX. How do I do it? Thanks!
- plemansMar 07, 2022Guru - Experienced User
What operating sysem are you running?
did you try uninstalling the wifi card drivers and then installing the new?
Just curious because I had an old 7260 sitting around and I tossed it in my laptop and installed drivers and it worked with my RAXE500 and my Orbi RBK752.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
