tslapnicka
Jan 08, 2021Follower
wifi connected, no internet connection
Bought a nighthawk router ( model RAX10) and have wifi connectivity but not internet. Have done a reinstall , a power up but no change. I have Spectrum as my ISP but have not contacted them directly.
What is my best way to get the router functioning.
1 Reply
What modem/gateway do you have?
Try this:
power off the modem and the router. disconnect all cables from both (even coax from modem). Wait 2 minutes.
then connect coax back to modem and power it on. give it a couple minutes to fully boot.
Then connect lan cable from modem to wan port on router.
power the router on. Wait a few minutes for it to fully boot.
Then try setup.
