Debiswan's avatar
Debiswan
Follower
Mar 01, 2024
Wifi connection to ios devices
All of my ios devices are no longer connecting to the router and all google devices are running slow. Is there an update I need or a firmware update?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Hard to tell if we don't know what Netgear devices you are using.
    Your message has things in the right order. Your subject has things the wrong way round. Look into ios connection to Wifi devices. In that case look into this:
    NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
    The first thing to try is a network reboot.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
