Th3Alchemist
Jun 08, 2020Aspirant
WiFi connection Unstable
I just got this new Router. Freshly installed and upgrade to the latest firmware (Firmwareversion V1.0.3.80_1.0.1). I've manually chosen a wireless channel that wouldn't interfere with the one if my ...
Scottish
Jun 08, 2020Tutor
Long shot but is your dhcp lease time 60 secs?
Scottish
Jun 08, 2020Tutor
Pressed the wrong button.
also see two ips there are the MACs the same across all those logs ?
- Th3AlchemistJun 08, 2020Aspirant
Couldn't find the DHCP lease time. Also those MAC Addresses are different.
Wireless Setup:
- AX Enabled
- Smart Connect Enabled
- 20/40 MHz Coexistence Disabled (Default)
2.4GHz:
- Channel set manually
- Mode: Up to 600 Mbps (Max)
- Transmit Power: 100%
5Ghz
- Mode: 2400 (Max)
- Transmit: 100%
Both WPA2-Personal[AES]
LAN Setup:
- IP Address: 10.0.0.1
- IP Subnet: 255.255.255.0
- RIP Direction: Both (Default)
- RIP Version: Disabled (Default)
- Using Router as DHCP Sever (10.0.0.2 - 10.0.0.254)
- No Address Reservation
QoS Enabled (But also works terrible)
- ScottishJun 08, 2020Tutor
So that I understand 10.0.0.7 is being assined across two different MACs ? Check that...7 isn't static on a client and within the DHCP scope. If so reduce the scope or set the client to DHCP assigned.
but mostly just a guess as the logs don't show much.
Sorry I wasn't more specific;
This is just small fraction of the log. It extends to a lot more. I have around 6 different wifi clients. All get the same problem. Some connected via 2.4GHz, other 5GHz.
Later I will backup my settings and restore to factory defaults.
