Bjwim71
May 09, 2019Initiate
WiFi cutting out
Got a new router and my internet seems worse than with my old one. When it’s on it’s great but then I get random “cannot connect to the server” on the most random things. iPhone apps, Apple TV (that’s...
michaelkenward
May 10, 2019Guru - Experienced User
How did you go about setting up the new router?
Did you just remove one and slap in a new one?
You might do better to reset everything on the network, including the modem, so that it forgets any assignations with the older kit.
Your wifi clients and networked PCs may also need an introduction to the new router.
Firmware is updated and yes it’s a router issue.
First, without knowing the number we do not know that the firmware really is the latest.
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
Second, I have seen many a "router issue" that turned out to be something very different. Again, I don't jump to conclusions.
It might also help if you told people what the modem is in front of this router. The model number could be useful.
Bjwim71
May 13, 2019Initiate
RAX80.
Modem was reset, and confirgured properly. That was the first thing I did. I reset the modem back to factory whenever i attach a new router. Issues still persist. Firmware is 1.0.1.56. Has to be a router issue at this point. Like I said, any router I plug in works without interruption.
- Christian_RMay 14, 2019NETGEAR Employee Retired
Hello Bjwim71 - I'd like for support to get in contact with you for further assistance. Please send me a message with your contact info and serial number.
~Christian- Goody224May 18, 2019Aspirant
My router is also cutting out. Loosing WiFi about ever 8-10 min then comes back on. I plug my old r7000 back in and everything is fine. Using the cm1000 modem. Everything has been reset several times. But the router still interrupts the signal.
- Christian_RMay 20, 2019NETGEAR Employee Retired
Hi Goody224,
Would you mind answering the questions below to help us understand more:
1. What firmware is the RAX80 currently on?
2. When you lose WiFi, is it lost on all devices connect to the WiFi network?
3. Have you gotten a chance to disable AX WiFi to see if your issue persists?
-You may refer to page 94 of the user manual to disable AX WiFi: http://www.downloads.netgear.com/files/GDC/RAX80/RAX80_UM_EN.pdf
Looking forward to hearing back from you
~Christian
