Bjwim71
May 09, 2019Initiate
WiFi cutting out
Got a new router and my internet seems worse than with my old one. When it’s on it’s great but then I get random “cannot connect to the server” on the most random things. iPhone apps, Apple TV (that’s...
Christian_R
May 20, 2019NETGEAR Employee Retired
Hi Goody224,
Would you mind answering the questions below to help us understand more:
1. What firmware is the RAX80 currently on?
2. When you lose WiFi, is it lost on all devices connect to the WiFi network?
3. Have you gotten a chance to disable AX WiFi to see if your issue persists?
-You may refer to page 94 of the user manual to disable AX WiFi: http://www.downloads.netgear.com/files/GDC/RAX80/RAX80_UM_EN.pdf
Looking forward to hearing back from you
~Christian
todd1010
May 20, 2019Apprentice
Mine is (I believe) the same as I've read here. Netgear tech support has downgraded my firmware and it fixed the issue where it would get 1GIG speeds when connected via wired line. But this was going on before and after the firmware downgrade.
They've now escalated it to Level 3 engineering department in Taiwan. They remotely access my computer last night but I have no idea what they did, what they found out, ideas to fix the issue...nothing.
If I don't get something straightened out within a few days, I'm going to have to take this thing back. I don't have time to pay $399 for a wireless router and still be a beta tester.
