Hunghein
Jun 25, 2022Aspirant
Wifi devices not connecting to rax75 after power loss
Power loss and doesn't allow all devices to get connected when power comes back. Sometimes it will work after power cycling the router again, or turning this off, then modem, turn on modem and the rou...
microchip8
Jun 25, 2022Master
Have you done a factory reset?
Static IPs are assigned to the device(s) itself and not on the router. On the router, you assign reserved IPs.
- HungheinJun 25, 2022AspirantMeaning start all over again? No and it doesn't make sense to do that all time. Trying to find a different solution.
- plemansJun 25, 2022Guru - Experienced User
what modem/gateway do you have?
Are you cycling the modem too? If so, power both off, then power the modem on (with nothing connected) and give it 2 minutes. Then power on the router and give it a bit to boot up.
- HungheinJun 25, 2022AspirantThanks but I tried all the power cycling for my router and modem.
Am not sure what my modem is but it's for fiber optic connection.
