randomlarka
Apr 30, 2025Initiate
WiFi Disconnecting on Android After Using Delta Executor – Network Conflict
I’m facing a strange issue on my home network that I’m hoping someone can help me troubleshoot. Recently, I started testing an app called Delta Executor on an Android device (Samsung Galaxy A52). It...
- May 02, 2025
If it was triggering something on the router, every device would have issues. Not just the one phone running the app.
So I'd be thinking its causing something on the phone.
Apr 30, 2025Guru - Experienced User
Or the app is causing something on the phone itself to cause issues.
If zero other devices have issues and this issue only happens after using the app, what makes you think its the router and not the app causing a conflict on the phone?
randomlarka
May 02, 2025Initiate
I agree it seems app-specific, but I’m curious if it’s triggering something at the network level too (like flood protection or a security filter), since the disconnect happens exactly when the app starts. No other apps cause this, and the phone works fine otherwise.
- plemansMay 02, 2025Guru - Experienced User
