flamesafe
Oct 27, 2020Follower
Wifi Disconnection-restarting computer to connect
After installing my Nighthawk 6-Stream Wireless Router I have experience a problem I did not experience with my former wireless router. At least once a day I have to restart my computer to recover a connection. This is the only way to recover my connection. If I try to reconnect in my network settings it will not connect. I believe this is a possible driver issue. I did not have this problem until I installed this router so I know that my computer is not the problem. Anybody experience this?
1 Reply
- Christian_RNETGEAR Employee Retired
Hello flamesafe,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
