Rickyhu
Feb 09, 2021Aspirant
WiFi doesn't work on rax35
Hey everyone. I have WiFi problem with my router. Internet works well, I can directly put cabel into computer. One time, I lost my WiFi signal, I rebooted router and after that I have never seen WiF...
Feb 10, 2021Guru - Experienced User
Have you tried a factory reset?
Push and hold reset for 7-15 seconds while its powered on.
- RickyhuFeb 10, 2021AspirantYes and It doesn't work to:(
- plemansFeb 10, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- RickyhuFeb 11, 2021Aspirant
I tryed to do tftp2 but on the middle of upgrade I got message "unable to get response from the server".
Also i tryed nmrpflash but probably i did something wrong or my knowledges not so good cuz when I tryed to start and i opend exe but I cant writr anything there. There was "press any key to exit"
