WirelessGrating
Nov 15, 2022Aspirant
wifi drops when laptop connects, wired connection fine
My Router: Nighthawk RAX43 Firmware Version: V1.0.12.120_2.0.83 I have been using this router in my small office (4 people) for a few months with no issues. Recently (no manual f...
- Nov 16, 2022
FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update?
Users reported having problems with this version of FW:
If the factory reset doesn't resolve this issue, you might revert back to prior working version of FW.
I performed a factory reset and manually added all my settings as well as set the DHCP range to .100 to .200. So far so good and things seem to be working. I'll keep an eye on it. This is not a good look for Netgear...
Thank you FURRYe38 for your help.
Nov 15, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
WirelessGrating
- I am in a shared business incubator building on a university campus. I do not know what network hardware they have in the server room. I imagine it is enterprise grade and running on a T1/T3 line.
- Yes I am running on auto channel on 2.4Ghz up to 660Mbps. The 5Ghz is set to channel 44 up to 3600Mbps. I haven't tried other settings for channels. I'll give it a shot but I don't hold out much hope.
- Being in a shared space, yes there are quite a few wifi buddies nearby. A SSID scan shows 15+ SSIDs in the area. It was never a problem before and looking at a wifi scanner the signal from our router is the strongest.
- The router has been power cycled many times while troubleshooting. I am unable to power off the modem as it is in the server room of the shared space.
- I have not done a factory reset. I will give that a shot. If I wanted to revert to the previous version of firmware, where would I find that file?
Thank you for the reply, I appreciate it!
- FURRYe38Nov 15, 2022Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?- Being in a shared space, yes there are quite a few wifi buddies nearby. A SSID scan shows 15+ SSIDs in the area. It was never a problem before and looking at a wifi scanner the signal from our router is the strongest. < I'll have to check with my RAX50 as I don't remember right off hand, however might see if there is a power setting for wifi signal. If you have lots of neighboring wifi signals, lowering the power on your router can help with interferences from neighboring wifi signals...Maybe power setting under Basic Tab/Wireless or Under Advanced Tab/Advanced Settings/Wireless Settings/ Just not sure if these RAX models have this feature support or not.
- WirelessGratingNov 15, 2022Aspirant
I dont see any power options under the basic wireless settings.
Under the advanced wireless settings I have a few options.
- Enable (checked)
- Fragmentation Length (2346)
- CTS/RTS Threshold (2347)
- Beamforming (checked)
- MU-MIMO (unchecked)
- Disable PMF (checked)
Dang, Ok, If you don't see that then I guess not. Lowering the power helps with wifi noise. Let us know if the other suggestions help.
