BarryD0706
Feb 08, 2021Aspirant
WiFi Easy Connect not working with RAX120
I have a LaCross weather station that uses WiFi Easy Connect to connect the device to my network. (There is a bar-code on the unit that their App scans. You then enter your network password and it is...
BarryD0706
Feb 11, 2021Aspirant
Christian_R wrote:Hi Barry,
Were you able to perform a factory reset by holding down on the reset button for 15+ seconds?
Christian
Wouldn't the factory reset I did in the admin panel be the same thing?
Barry
Christian_R
Feb 11, 2021NETGEAR Employee Retired
Hi Barry,
We recommend performing a hard factory reset using the reset button.
Christian
