minkdnd
Mar 22, 2023Aspirant
WiFi filtering restricting security cameras from connecting?
 Attempting to reconnect my Arlo pro4 wireless cameras to my network after installing my new RAX50 router.  Cameras will not connect after many attempts.  Arlo chat is asking this question:  Is there ...
- Mar 22, 2023Thank you for your response. It seems that I have fixed the problem on my own after some research on Arlo site. Thanks again for your response. I believe it was not a router issue but an issue with the camera app. I was able to connect through my laptop. Have a great day!
Mar 22, 2023Guru - Experienced User
What actual arlo model is it? There's a lot of pro 4's. (might also post in the arlo forum)
You have the RAX50?
What firmware is on it?
Your modem is the cm2050v?
Are you using parental controls or access controls? that'd be something to check on the router.
Any special characters in the ssid/password?
- minkdndMar 22, 2023AspirantThank you for your response. It seems that I have fixed the problem on my own after some research on Arlo site. Thanks again for your response. I believe it was not a router issue but an issue with the camera app. I was able to connect through my laptop. Have a great day!
