xmillies
Sep 12, 2019Aspirant
Wifi in large house /garden - rax200, AX8, orbi, ...
Hi, I have today Nighthawk R7000. I want to deploy wifi in my large house and in garden. I have already a gigibit fiber (with a router) and behind a firewall. The firewall is the entry poin...
xmillies
Hi,
The house is made with hollow block.
The size is around 15 m x 10 with 2 levels.
The garden is aroud. Up to 10 meters around.
I agree satellites could be the answer.
So do yI need to take wifi 6 router and orbi or ax8 ?
Or directly several ax8 or orbi ?
Xavier
Sep 12, 2019Guru - Experienced User
xmillies wrote:Hi,
Xavier
Hollow cinder block? aka concrete/cement block? It does a great job of blocking wifi. Even if you go mesh, many have reported issues because the material blocks the wifi backhaul. This'll be the same with wireless AX as well.
You probably going to need to play around a little to figure out which system is right for you. I can't say which is going to work the best as I'm not at your location to test/setup.
- xmilliesSep 12, 2019Aspirant
Hi,
The brick is like this one:
https://media.castorama.fr/is/image/Castorama/3661216103502_01c
The idea could to put orbi or ax in the roof on the extremities for instance (2 or 4).
It should work.
Actually i have a Nighthawk 7000 for the wifi. We can get wfif quite almost everywhere in the house (sometimes low level).
The recommandation is AX8 or orbi ? What are the differences ?Xavier
- plemansSep 12, 2019Guru - Experienced User
AX8 isn't a mesh system. It is the next gen wifi but is a single routing device.
If you're wanting multiple access points I'd go an Orbi setup. It allows you to add on satellites for additional coverage and even has the option of an outdoor satellite. RBS50Y There is the option of Orbi AX which is their newest orbi setup running the AX specs. Its quite expensive though.
Yes, Netgear Orbi AX Mesh WiFi (RBK852) is great.
I think this is better than the RAX200 wifi 6 for my use case.Do you agree ? Or RAX 200 and 1 or 2 orbi ?
