mjikram
Mar 24, 2019Aspirant
WIFI ISSUE (ax8 6000 router) cannot connect my laptop
I have bought new ax8 6000 router. I cannot connect my 2 laptop. It does not get any wifi signal from my new router. Strange thing is my old laptop I can get signal but new 2 laptop doesn't get any 2...
schumaku
Mar 24, 2019Guru - Experienced User
Disable the AX mode for the moment - WiFi settings.
- mjikramMar 24, 2019Aspirant
Thanks man !!!! It is working,,,,, I really appriceat your help.....
- schumakuMar 24, 2019Guru - Experienced User
Glad it helped - pretty poor workaround, fine as long as you have no 80211ax (Wi-Fi 6) clients around, I must admit.
- Redtulips7Mar 24, 2019Luminary
You rather off buying a AC Router if you have to disable AX mode to connecct Laptops...
Some interoperability issues are predicable when jumping on pre-standard early technology which has not gained sufficient field test coverage before.
