Intro
Jul 29, 2020Guide
WiFi issues on CAX80
Hello everyone, I purchased a CAX80 trying to get off of rental fees through Cox Communications but I've seem to hit an issue. Looking at all my WiFi enabled devices they show a full signal while loo...
Intro
Jul 29, 2020Guide
I did forget to mention that: Yes, my wired connection is getting the speeds its supposed to. My WiFi speeds are poor and there seems to be a bad latency issue. Wired I'm pinging in the ranges of 7-9 consistently Wireless between the ranges of 22-300+
- Shanew29Aug 02, 2020AspirantI've had similar issues. Not as bad you though. Only when playing online games I downloaded from Google play store does connection in game on game state connection lost, reconnect to game. When playing another game it buffers for a few or lags. I didn't experience this at all on my Motorola mg7550. Any help would be appreciated đ. Otherwise this $429.99 is going back. Junk.
- plemansSep 01, 2020Guru - Experienced User
Is your tv on the 5ghz stream or the 2.4ghz?
Are you using smart connect?
what firmware version is on the router portion of the CAX80? (i know the modem and router have seperate firmwares)
- IntroSep 21, 2020Guide
Sorry for the delayed response was looking at other threads that recently popped up and have been working with the netgear tier2 support over the phone and through email and this is a mess. I'm really coming to the conclusion that the CAX80 just wasn't ready.
I've tried both 2.4 and 5ghz
I've played with smartconnect on and off checked interference channels I've done a lot but but have been left with "engineering has replicated the issue and are trying to sort it out" But still to no avail.
Firmware V. 1.1.0.41
- plemansSep 21, 2020Guru - Experienced User
I'm wondering if it isn't an issue with cox. I've seen mutliple reports about the cax80 but the common thread seems to be when its a cox provider. I've used one on xfinity for months and the thing was a rock star.
