HoweverYouWant
Oct 16, 2024Aspirant
WiFi issues with Netgear Nighthawk AX2700
So I’ve been having off and on issues with my WiFi recently. I’ve spoken to my internet provider Spectrum and tried rebooting both the modem and router multiple times. Spectrum says I’m getting the nu...
HoweverYouWant
I have the RAX29 model router. I’m having issues with low WiFi speeds and spectrum said that it looked like I was getting good speeds on their end. I’m connecting my phone, a tv, my Xbox, kindle and laptop to the router. The firmware version is v1.0.13.102_2 and I’m not sure what the mfr and model number of the modem is or where to look for it. And I’ll look at the settings you suggested.
Oct 16, 2024Guru - Experienced User
What speeds are you expecting to see?
Would need to test with a wired PC to check and compare speed test results.
Ask the ISP about brand and model of modem your using.
- HoweverYouWantOct 16, 2024AspirantI’m currently on their 400 Mbps plan but I’m only seeing one to two Mbps download.
- FURRYe38Oct 17, 2024Guru - Experienced User
Same speed results on a ethernet connected PC?
Same speed results on a ethernet connected PC connected directly to there modem?
- HoweverYouWantOct 17, 2024AspirantI sadly don’t have an Ethernet cable but I really should get one. But I would prefer not to have to get a bunch of cables attached to everything I own since all of them are in different parts of the house.
