georgewade
May 17, 2020Aspirant
WiFi network
Good evening all; I just successfully installed and registered my CM1150V modem router. I have internet and voice but I'm a little lost here as to connecting to WiFi. My pc has installed the device a...
- May 22, 2020It’s not a router. No wireless functionality. Great modem, but don’t expect much help with proper installation from Comcast during COVID. I’ve tried absolutely everything using this modem with the new Orbi RBR850 router (part of model no. RBK853), and after trying everything with tech support, I can pretty confidently say that this tech is as advertised and, if properly installed, is superior.
I’m running 850 download / 42 upload / 15 ping on the Orbi App from a distance of 20 feet from the router. It’s mind blowing, so don’t give up. If I see your post, I can answer a lot of questions, but first you need to get a suitable for this modem router.
RAXXXSTER
- CM1150V WiFi6 modem
- ORBI RBK853 WiFi6 whole home mesh
-3300 sq ft, 2-level, 50 yr old home
RAXXXSTER
May 22, 2020Initiate
RAXXXSTER
RAXXXSTER
- georgewadeMay 23, 2020Aspirant
Thank you both for your prompt response. I was able to figure out that this was indeed a stand-alone modem. But my local walmart had a Nighthawk AX4 AX3000 4 stream Wi-Fi router on clearance for $99. Less than 15 minutes after getting it back home I was up and running. The Xfinity tech had to come back and install a "sidecar"(?) to the modem in order for the security system to connect to my wifi. He also assured me I was light years ahead of the speed provided by their Arris device. And I'll get back my money in about a year without the lease fees.
